JCR-1's avatar
JCR-1
Air Cond coolingThermostat (line voltage)
My Coleman Mach air cond fan continuously runs when the thermostat kicks off the compressor . Since it is rather noisy I was wondering if anyone wired in a thermostat to where the whole unit shuts off when desired cold temperature is reached. I am interested in recommending a good thermostat and best location like the circuit breaker panel as I think the A/C has its own dedicated circuit or other..Thanks
  • TomG2 wrote:
    There is a company called Airswitch that does exactly what you want.
    http://airswitchrv.com/products.html
    That is it.. Perfect.. Thanks for your help Much appreciated
  • There is a company called Airswitch that does exactly what you want.
  • My Lance trailer has a Coleman Mach roof air direct blow unit. Has a wall thermostat Coleman Mach unit. On the front it says Coleman Mach RV Comfort.HC. Has a fan switch that has---Fan-High,Low, Auto position. In auto position fan shuts off with compressor.
  • JCR-1 wrote:
    Unfortunately there is no "auto" setting on this Mach Air Cond.
    That's because you didn't make it clear in your original post that what you have is a direct blow system with the thermostat controls mounted on the unit's ADB instead of a ducted system with wall mount thermostat that would have an AUTO mode. If this is important enough talk to a dealer about replacing that ADB with a ducted grill and wall mount thermostat.
  • Unfortunately there is no "auto" setting on this Mach Air Cond.When you set the thermostat (rotational dial goes blue to red) and you reach the temp you want the compressor kicks out , but the fan continues to run. I want to install a thermostat on the incoming 120 v line to control both fan and compressor to turn on and off together.
    The switch has off, low fan , high fan, low cool , high cool.Thats it no AUTO .
  • I do not think there is anything close to a plug and play thermostat that will replace the controls up on the ceiling unit.
  • Fan setting should be in AUTO........in auto it starts/stops with compressor
    In High or Low speed settings it runs....can also run when using t-stat for HEAT
    Now IF t-stat is broken (in auto and still runs) then either a new OEM t-stat or a Honeywell/Hunter digital can be used as replacement
    Post YEAR, Brand/Model of that Colemen-Mach for suggestion on t-stat swap
    Or ....place Fan in AUTO
    HERE is info on Honeywell Digital T-stat Swap
