CT_WANDERER's avatar
CT_WANDERER
Battery Line Voltage
Looking at my Morningstar TM45 today. I have for now, 3X 120Watt panels. Going thru the remote panel readings and paying attention to it. At the time, it is in PWM , I see battery voltage of 14.54, then if I go to where it gives me the battery sensor voltage I have a reading of 14.45 volts. The lost difference I assume is line resistance. My question, would you consider this .09 volt a high lost? I am happy with my solar system. Still have two more panels to added once I find the money. Just wondering. Thanks Gary
  • smkettner wrote:
    What is the programmed absorption voltage set point?
    Exactly where are the measured points? Battery terminals and controller output terminals?
    You have the battery sense wires connected? Are you reading voltage on these? what end?
    All these reading are off the remote TS45 panel. I assume the battery voltage of 14.54 volts is at the controller output. And the 14.45 is at the batteries post thru the remote sensor line to the controller. My Trimetic panel shows 14.5 volts, but it does not read that extra digit.
    I am running the #4 program on the solar charge controller. I believe the absorption set point is 14.4. If I understand the instructions. Gary
  • MrWizard wrote:
    quit worrying.. your doing great
    0.09v drop.. nothing to bother me
    i wish mine was that low
    i got a LOT of wire in my system and more drop than that
    but my solar and batteries keep chugging along
    As I said I am happy with the system, I felt like the drop was not bad. Just one of the number things I was looking at. Thanks all for your input. Gary
  • .09v is a bunch if the amps are very low, 20A not a bunch!
  • quit worrying.. your doing great
  • What is the programmed absorption voltage set point?
  • <1%
    What's the current?
    Measure before abs set point (bulk) AND current is high.
  • Gary,
    A lot depends on what instrument you are using to read that voltage.
    If you are not reading both with the same instrument, there can be calibration differences.
    If you are reading both with the same instrument, but that instrument is not true RMS then the PWM may mess up the reading.
    Matt
  • I think your being paranoid over nothing. Battery voltage is around 14.5VDC. That's good enough for most of us.
Having RV issues? Connect with others who have been in your shoes.24,377 PostsLatest Activity: Apr 11, 2026
