Reddog1 wrote:
SidecarFlip wrote:
PhilR wrote:
My NL camper has the fiberglass section (mount kit) that is designed to distribute the weight of the ac over a broader area. It comes on units that are factory "ac prepped". This is why the ac unit sits a little higher above the roof, and the 3 support pads on the underside of the rear part of the ac unit are too thin to fill the space and provide proper support. I am waiting for a call back from NL, but plan to remedy this situation in any event.
The Honda 2000 will run the Mach 8 9,200 ac unit with no problem.
"The Honda 2000 will run the Mach 8 9,200 ac unit with no problem" I bet it won't power anything else at the same time.
No, but that was not the question.
Wayne
2000W gives 16 amps.
My 12k AC draws 6.7 amp when running, so I would not hesitate to switch generator ECO off and run small oven as well.
But if you are in weather where AC cycles and it would happen in that moment, it all will go into stall.
