ah64id wrote:
Vision Type 81's are 7.5" wide, which is a bit too wide for a 225.
The Visions cannot be run with 225/70R19.5 tires (6.75" maximum width) - Most of those tires are limited to a 4000 lb rating. I wanted a tire rated higher the rim and that is why I went with a 16PR LRH 245 tire. I also figured the side wall would be thicker on the higher rated tire which would reduce sway. You can find plenty of 17" and 18" tires that approach 225/70R19.5 weight ratings, but I bet they will not be as stiff.
* I did find some 225's that were supposed to be able to work with a 7.5" wide rim, but can no longer find those links.
