- TUCQUALAExplorer25-40 psi, AND, do it 2 or 3 times!! Water vapor will condense in the low spots and elsewhere in the lines!!!
- Colo_TJExplorerBut there's plenty of room for the remaining moisture to expand.
It doesn't need to be dry. - TUCQUALAExplorerNo labor costs, no parts costs, just some extra time to be sure you hit all lines and faucets!!! Of course with your tiny home, you could blow into the hose and take care of the lines!!!!!
- tatestExplorer II
CopilotCompanion wrote:
tatest wrote:
I crank the regulator on my 150 psi compressor down to 25-35 psi for this task. Blowing out one water line at a time, it is unsual for this to empty the (not very large) tank, and if the compressor has to start running, it has enough output to maintain flow at this pressure setting. For his job, what you need is air volume, not pressure, since you are blowing out open lines and not building up pressure.
Off topic... Are you the voice-over guy?
Right to the point. Are you the new moderator? - rbpruExplorer IIFrom experience I would say it is less than what I used when I blew the check valve out in my camp water line connector.
My compressor is maxed out at 60 lbs. - I run about 25 PSI
- TimtationExplorerI use a vacuum, you only need to get enough out to leave room for freeze expansion, like lung power as previously posted.
44,029 PostsLatest Activity: Jan 18, 2025
