Cummins12V98
May 01, 2013Explorer III
larry barnhart wrote:Cummins12V98 wrote:
I probably have more pin weight than anyone posting so far, 4,500#. Weigh your rig loaded and unloaded. Use the tire inflation chart associated with your tires.
I run 80 in the front all the time is is a bit high on the chart but it averages out for the edge wear fron turning.
On the rear I run 55 loaded and solo 45.
My truck is a 3500 RAM Dually.
If you are running 80 in the rear with a dually your rear tires will be bald in the center in no time and I would hate to ride in your rig!
27000 combined weight and 55 lbs of air pressure in the rear tires seems very low to me but if it works it works.
chevman
It is actually 28K now! Gained a few since joining!
Use the weight charts that is what they are for then add 5psi.
44,058 PostsLatest Activity: Mar 16, 2026
