transamz9
May 02, 2013Explorer
Hannibal wrote:transamz9 wrote:Cummins12V98 wrote:transamz9 wrote:
I run 55 in the front all the time and 65 when towing and 45 when empty in the rear but I run 8 ply tires so 65 is my max.
Why would you run "D" rated tires when "E" are standard?
The tire I am running is not made in an "E" in the size I'm running. The "D" That I have on the truck has the same rating as the OE.;)
So you tow "18,000 lbs" with a 2500HD pickup truck with D rated tires at 65psi?:h
First off, I could tow 100,000 lbs with passenger tires and not have any effect on the tire if it's with-in it's carrying capacity so keep scratching your head.
44,058 PostsLatest Activity: Mar 16, 2026
