Anyone know what air pressure to use in the trailer wheels? My manual says check the tires side and the tire side says check the manual. Local RV dealer says 50#, which sounds high to me. What's ...
Not sure about trailer tires, but I would assume that the theory would be the same.....you can weigh the trailer, and then divide that weight by 4, to get the weight per tire. Then check the tire mfgr's website or look for a chart on Google (I believe Michelin has one) and pressurize the tires to the number listed. Maximum pressure is OK, but if you can get them closer to what they are supposed to be, so much the better.
