JRscooby
Sep 01, 2021Explorer II
Air shocks are not normally the best shocks for ride, but would be better than the none most trailers come with. And to use for leveling you would need valve for each side. And valves mean more connections. More chance for leaks. And any air that leaks will need replaced, so will need compressor on demand, plus valves/switches to hold you level, more doors for Murphy.
Now if you where to replace the springs with bags and good shocks, you could improve the ride, but not sure it would be that much better than good springs with good shocks. Now if you put something over the tires, so you could park on boards to level, dump air, lower step height, and lock trailer in place...
