Huntindog
Sep 02, 2021Explorer
Rbertalotto wrote:I am VERY interested in what you do. I have been considering bags myself. Mainly for the ability to raise the trailer for ground clearance when needed getting into a boondocking site. I cannot raise it permanently as it is already at 13'6", and bridges could be an issue.
A few additional comments to my original post....
The trailer I have is a Forest River 19RR TOY HAULER.....The load varies immensely...with water and motorcycle, upwards of 1000# +/-....The triler has a payload rating of somewhere around 3000#...
I've already replaced the equalizer with Dexter EZ-Flex equalizers and all wet bolts with bronze bushings ....HUGE IMPROVEMENT!
This trailer has already broken two leaf springs. And both times with no motorcycle aboard. I'm convinced the factory springs were not rated properly. Three weeks ago I replaced all the springs, brakes, bearings and races....and welded on new spring perches and flipped the axle to below the springs, giving me more room for my airbags/air shocks. With both devices I can simply run them at 10psi and they will have no effect on the original suspension. And using them to quickly level the trailer at a rest stop for an overnight would be a tremendous benefit. This trailer already has a heavy duty Vair compressor and 5 gallon air tank so the issue of "air" is no issue.
Still need to decide on air shocks or air bags......I'm absolutely going to do one or the other.
