Rbertalotto
Sep 03, 2021Explorer
But how much lift articulation are you really going to get and how much trouble is that worth, as opposed to putting out boards or an Anderson leveler?
I have the the red plastic, under wheel, wedge type levelers....a great solution, but a pain when they are covered with mud and need to be deployed and undeployed and stored etc...Plus where I usually camp, I need to also bring a couple plywood boards so they don't sink into the ground. And a few trips in and out of the truck to check level if I'm alone.
They give me about 3.5" of lift. I placed a bottle jack between the frame and the spring perch on my trailer and I can get just about the sale lift with this method.
Nothing to touch, nothing to store, nothing on the ground.....
And I realized I really only need one axle to be manipulated....You don't have to do both. But stability improves if you do both.
Now, If there was a way for the lift mechanism to push against the top of the tires, rather than the axle, this would REALLY stabilize the trailer from rocking, just like those devices you install between the two wheels!
