JRscooby
Sep 05, 2021Explorer II
Gdetrailer wrote:
They do make stick on graduated levels that readout in inches.
They also make graduated round bubble levels.
Inch reading will take the guessing out of your setup at a much lower cost than rigging air shocks and may be more reliable.
No sense adding extra things to break, RVs break easy enough..
If you are backing up a ramp until level, there is no need for the inch marks. Building a ramp, parking on top, the marks are some help, but if using 2X8s they leave some to be desired, IMHO Off by 1 inch? When on 2X, off 3/4 other way, do use a block or not? And if using the interlocking plastic even more confusing because the 2nd and higher layers don't lift as much as the first. This is why I mark the level in blocks.
I had 2 issues with the little stick-on levels. First, the 1 mounted on the front was too small for me to read from driver seat. Found a much larger tube/ball level. 2nd, the 1 on the side for front/back level, over time the sick-on let it walk over time. Found my eye debating the bubble. Re-adjust, and a couple of screws cured that (I trust my eyes, but DW trusts hers. Best to have a bubble)
spoon059 wrote:afidel wrote:
Maybe I'm just unlucky but in the first 7 months of owning my new trailer I've been on sites that exceeded the height of my Andersons 3x. I end up building platforms out of 2 stacks of 3x Lego bricks with another 2x as caps. I use the Andersons as ramps to get up onto and off these towers.
Situations like that I would either try to reposition my camper to be more neutral before leveling, or I would use my shovel to lower the high spot. I wouldn't want one side of my camper to be more than 4" higher than the other. Then you start having issues with the steps, access to outdoor kitchen, instability when stabilizing, etc.
If you have exceeded the height of your Anderson's (4") by 3 times, thats a foot off level over 8 feet wide. Are you camping on the side of a mountain?
You read he is a foot off? I read he had issues on 3 sites
By nature, over time most soil will settle to the point if there is a slope most water will run off. When you start digging you loosen the dirt. Water is more likely to carry the dirt away. And it is more likely to soak in, so the next person has a mud hole.
Carry a compressor? Dump the air out of high-side tires. At least no problem for others.
