Montana_Mike
Feb 26, 2014Explorer
Air Shocks
What about air shocks on a towing rig. Anyone use these instead of air bags? Or is that to much pressure on the shock mounts?
Lynnmor wrote:Are you saying the rear end should be raised to the unhitched height? If so, why?
If you have soft rear springs then even a correctly adjusted WDH will not raise the truck to where it should be.
