Montana_Mike
Feb 26, 2014Explorer
Air Shocks
What about air shocks on a towing rig. Anyone use these instead of air bags? Or is that to much pressure on the shock mounts?
Lynnmor wrote:A trailer with 1000# TW and a correctly adjusted WDH would not add 500# on the front axle. After adjusting the WDH, the net load change on the front axle would be approximately zero, and a load of about 750# would be added to the rear axle.
Just for grins, an example would be a trailer with 1000lbs of tongue weight. You adjust the WDH to put about 500lbs on both the front and rear axle. Add some cargo in the bed. That might put the front down 1/2" and the rear down several inches. Do you really want to drive with the headlights blinding oncoming traffic?
