- bighatnohorseExplorer IIVery interesting. The air foils that I've seen were fairly spendy.
Would you mind telling how much they cost. - the_tc_lifeExplorerinteresting. ill be looking for a report on how it works for you.
- Art_SchlangenExplorerI just installed them on the bunk over the cab. I get a lot of wind noise inside the cab. Some guys put air foils on there rigs. It was mention about these air tabs in a older post. I found a local company that carried them so I wanted to give them a try. I hopping it will cut the bugs also. I will keep everyone inform on the results. I might mention they were easy to install I snap a chalk line use my thumb as a spacer. Then you peel the paper off and it has sticky on the back of them. Simple.... ART
- harold1946ExplorerInteresting; Be sure to report the results. Never see them installed under the cab over before.
- pianotunaNomad IIIHi,
Did you install them at the rear end of the tc? And on the sides and top surface?
44,066 PostsLatest Activity: Oct 04, 2013
