Art_Schlangen's avatar
Jun 13, 2013
Air Tabs Installed
Well I pull the trigger to and install Air Tabs on my camper. Hoping to cut the wind noise around the passenger door and reduce bugs. We will see how it works. ART
  • Very interesting. The air foils that I've seen were fairly spendy.
    Would you mind telling how much they cost.
  • interesting. ill be looking for a report on how it works for you.
  • I just installed them on the bunk over the cab. I get a lot of wind noise inside the cab. Some guys put air foils on there rigs. It was mention about these air tabs in a older post. I found a local company that carried them so I wanted to give them a try. I hopping it will cut the bugs also. I will keep everyone inform on the results. I might mention they were easy to install I snap a chalk line use my thumb as a spacer. Then you peel the paper off and it has sticky on the back of them. Simple.... ART
  • Interesting; Be sure to report the results. Never see them installed under the cab over before.
  • Hi,
    Did you install them at the rear end of the tc? And on the sides and top surface?
