mr_andyj
Jul 12, 2021Explorer
Your truck will sag. Will it sag enough t bother you? You must tell us.
Bags will be very nice and you can set the ride height where you want it.
My guess based on no info is that you would want to put bags on.
Important!!! For TCs the bags are best placed under the frame, WHERE THE SPRINGS ARE, never inside the springs. Placing them inside could make the truck more unstable as you are supporting the weight above the springs from a more narrow stance. Like standing with your feet together or with feet spread apart, which is more stable?
For leaf spring trucks it is easy as you just put bags on top of the leafs, for coil springs it gets a little more complicated and these are the ones that tend to get put inside the frame. For trailer help this is not important, but for TCs it matters!
