BigfootBill's avatar
BigfootBill
Airbags not working with overloads
I just put on Airlift airbags on my 3500 and am finding that it is preventing the load from being carried on the overloads.
I have done a fair amount of googling and am not finding people with my particular issue, could just be me?
When I bought my camper in Ohio, it loaded up nicely and the truck sat with the frame perfectly level. I was happy with how it rode for the most part but some of the harder bumps on 90 felt like I was hitting the bumpstops so I was hoping to get a little extra cushion. I read some of the various options and didn't want to mess with the suspension (engage overloads earlier, etc), just wanted the option to raise up a little bit if the situation dictated.
I added the airlifts, which install in the place of the bumpstops and am now finding myself in the situation where the upper and lower brackets plus airbags are fully collapsed/pancaked with 5psi and the overloads are just barely touching the stops on the frame. Fully aired down, I am also no longer level when loaded up which means I will always have to block up the front when parked.
Now it looks like if I want to use the airbags, I will need to put some extensions on the overloads which will put me even higher in the rear for normal travel. I have no interest in raising the front to compensate for the additional lift in the back, not sure what my options are even if I did with a 2wd.
Has anyone gone on this journey and have any suggestions?
