BigfootBill
Jul 21, 2020Explorer
For those of you following along, I added a 2 inch spacer at each of the 4 contact points for the upper overloads and when the camper was loaded back on the truck, with 5 psi in the bags, the truck bed was sitting 1/2 inch higher than before. 75psi took the bed up another half inch to give me about an inch of travel. I am taking it out this weekend and will play around with the pressures but right now, I think I will go with the KKeller suggestion and do some surgery on the lower airbag mounts.
The design is set up so that the location of the bag in relation to the bracket can be adjusted with slotted holes, but now that I know where it should be, I can mark the mounting spots and lose the wrench space.
