BigfootBill
Jul 17, 2020Explorer
Thanks all. I am going to take some measurements and then pull the airbags. With the airbags fully aired down to 5psi, sitting on their internal bumpstops, the camper already feels quite a bit more unstable than before, before putting air in and getting off the tips of the overloads. In order to fix this, I see needing to do additional improvements (more money) in order to try to get back to where I was stock.
I have the first camping trip coming up next week so I am going to go back to where I was before, fully stock and see how it rides loaded up with water and family. I believe in the future I will be looking towards aftermarket axle bumpstops, hydraulic or other progressive design and overload extensions or adding a third overload/helper spring to each side.
I do like the idea of an adjustable spring rate, which you get with airbags. From my initial searching, I could also get that with torklift lower stableloads but would need to lift the camper off the truck to pivot them out of the way when I got to where I wanted to stop for the night. Not ideal, but nothing ever is.
My last option is to modify the current airbag brackets to try to get more compression room so that they are not flat when the truck is level but I'm not sure there is enough room based on their design.
