BigfootBill
Jul 17, 2020Explorer
WyoBull wrote:
I am wondering if it is a Dodge Ram issue as I have not heard of this before with the Super Duty's?
I am thinking it may be a 2wd issue. I had gotten the numbers from airlift when I was researching what bags to get and both the 2wd and 4wd models had the same minimum size, when fully compressed, but the 4wd had 2 more inches of travel in the bag. It is my understanding, without doing any actual research, that the 4wd has the rear blocked up to maintain the same truck rake or angle that the 2wd has, while the front is higher due to the design. This means that the distance from the frame to axle is larger in the back when the truck sits level, as the front is higher.
I am still not sure if this is actually the case, however, as I would guess I need to raise the front about 2 inches to make the truck level when the airbags are sitting on their internal bumpstop.
Maybe the question I should be asking is how many people are actually level in the camper when they pull into a level parking spot.
