KKELLER14K
Jul 19, 2020Explorer II
Some more advice. Take the bags off and leave the brackets on. With the truck unloaded look at the distance in between the lower and the upper bracket. Then load the truck up with your overloads engaged. It should be obvious that the space is too small for the bags to fit. I modified the lower bracket to get the space needed for the bags to fit.
You will have to cut and re-weld the lower bracket down as far as you can get. It stretches the bag out unloaded somewhat but I had to do this for the same reason. The air bags were bottoming out before the overload springs were completely functional. Don't trust that the stock brackets are correct...mine defiantly were not... the height of the bracket was incorrect. Mine works great now. Look and see if you have any space between the lower bag bracket and the spring pack bracket.
