towpro
Jul 20, 2020Explorer
I have had several rams with top overload springs. the problem I have found is some loads your springs are just hitting the overload springs, but when you hit a bump and "bang" the upper spring hits the overload bracket and you feel the jolt in the suspension.
now you have air bags on and it jacked up teh truck so your sitting higher, and I bet the overloads are banging even harder when you hit them.
ON my 2006 I replaced the thinner overload pads on the frame with a set of these (you will need 2 sets, or 4 bumpers)
click here
they are not designed to be used in this job, but I ran them 100,000 miles with different 5th wheels and a Wolf Creek truck camper with no problem (my brother still owns the truck with them installed). what these do is as the weight goes up, these hit the springs sooner, but because of the holes in them they compress some and take the JOLT out of the springs banging into the frame perches.
click here
