1971amerigo wrote:
I might add to this topic.
A set of automatic tire deflators is a great investment.
I have purchased the Staun TRYE DEFLATORS.
They work great!
Until they don't. :)
Something the off-road crowd has learned is to keep a sharp eye on the "automatic" deflators because if one sticks (and they do) you will quickly end up with a flat tire.
I used to have the Oasis automatic deflators but they were problematic. Now I much prefer to use the Oasis manual defleators. They are not automatic and will indeed let all the air our if you let them but I have never been surprised by one. For my Bronco I simply screw on the first one, count to 20 and then screw on the next one. Repeat until I am back at the first tire and it is down real close to my desired trail pressure. Remove deflators in the same sequence and adjust tires for final pressure.
