joelyn's avatar
joelyn
AIRLIFT air bags installed?
had the airlift 88365 air bags installed on my 2012 ram 1500 truck on friday. Had just the airbags done and now thinking of getting a on board comp, done. My question is the airlift compressor cost about 500 bucks not including the install. CAN ANY COMPRESSOR be used for these airbags or does it have to be the same make a AIRLIFT COMP>?
thanks
āš Did you read the FTS "Announcement : READ BEFORE POSTING HERE"?
    Forum Technical Support (FTS) is reserved for questions related to the use of the Open Roads Forum sites,
    member profile and photo testing, and for reporting account issues. Please avoid using FTS for RV related
    questions. Instead, select the Sub-Forum which corresponds to the subject of your topic. Thank-you!
    Moved from FORUM TECHNICAL SUPPORT
  • I've had the air lift bags for a long time, I went with their on board compressor and I did because their compressor maintains a pre set amount of air in the bags at all times, I think about 5psi. It's not good for them to remain uninflated when moving.
    Mine have been on at least 10 years with no issues at all. I installed them myself btw.
    My compressor is keyed to the ignition so before I crank the motor, I give the compressor a minute to inflate the bags to the minimum pressure and then move the truck.
  • PatrickA51 wrote:
    This is just my opinion. You can purchase a Viair 12v DC compressor on Amazon or at 4Wheel Parts Warehouse. They are less than $200.00 Dollars on Amazon
    Viair 400P on Amazon.
    thanks, will check it out///// should they all have the same connections and fittings?
  • This is just my opinion. You can purchase a Viair 12v DC compressor on Amazon or at 4Wheel Parts Warehouse. They are less than $200.00 Dollars on Amazon
