I'd suggest you go and see the Lance in person. You'll be impressed:
SOME STANDARD STUFFLance Uses CNC Routers
45 Gallon Capacity On All 3 Tanks
Lite Ply (Birch) Wood Used
Azdel Composite Panels Used (No Wood (Luan) Used)
Ducted Heat 25,000 BTU
Black Tank Flush
One Piece
PVC Roof
12v & USB Charging Wallplate
LED Lighting Throughout (Inside & Outside)
Aluminum Wheels With Goodyear Tires
Lamilux 4000 Fiberglass (Made In Germany)
Huck Bolted BAL Frame (Not Welded)
Porcelain Toilet
Exterior Propane Connect
Dual Pane Skylights
SOME OPTIONSBackup Camera
12v 32" LED TV
160 Watt Solar Panel
19' Awning
Electric Stabilizer Jacks
Lift Kit Available 2 5/8"
Choice Of 3 Different Air Conditioners 9k - 13.5 - 15
4 Season Package (Frameless Dual Pane, Heated Enclosed Tanks, etc)
Phat Ladder
I'd be curious if A/S has dovetailed cabinets?
Lance Factory Construction Video
