DownTheAvenue
Feb 18, 2016Explorer
I have owned several Airstreams, and none suffered from water leaks in the traditional sense like an experienced RVer may be familiar with in conventional RV's. Since the roof is curved, a replacement A/C unit MUST be installed on a pan designed for the roof curvature and that particular A/C unit. Many units have been replaced without that pan, and while visually they look OK, they will for sure leak without that pan. The TV antenna can be a problem as well as the ceiling vents, but windows, doors, etc, have never been a problem but may require some caulking. Only a special caulk will adhere to the clear coated aluminium so be sure to use Airstream approved caulk.
The 1980's models required a strong bead of caulk along the bottom rub strip to prevent water intrusion along that area. The 1990's had some problem with water leaks at the front wrap around windows. But you never have to worry about de-lamination!
