- ksssExplorer
Cummins12V98 wrote:
ksss wrote:
Grit dog wrote:
Maybe? this will shame Ram into getting a better trans from the past decade or so into their big diesels?
On another note, the drug testing policy for the GM truck artistic designers is still not working in their favor. For the love of God, how does Chebbie come up with such a butt ugly nose and then keep using that design?
They use the design because it sells. Yes, it is more polarizing than it needs to be, but they have increased their marketshare since 2020, the start of the new design (which to be fair, may be inspite of its looks and not because of it). Either way, if it sells, it stays.
The reason they have improved sales is because they changed engine and trans components to keep up with RAM and Ford on SAE towing numbers.
Did GM take a survey asking what the 2020 to current buyer's decision process was when buying? If they did, this is the first I heard of it. I own one, no one asked me. So I am not sure where you got your statement from. If it as ugly as many think it is, why not buy a Dodge or Ford? The Ford has had more power and torque during that same period anyway. Also the engine is the very same engine I have in a 2018 3500, the tranny is of course an ALLISON 10 speed. - Pbutler97Explorer
Cummins12V98 wrote:
Let's make this perfectly CLEAR. The trans in the current GM's are only "BRANDED ALLISON". Makes me all warm and fuzzy.
RAM has a Chrysler trans and AISIN MD trans. Ford has its own HD trans. No smoke and mirrors with either of them.Cummins12V98 wrote:
I am assuming yours is actually built by Allison?
To be clear I am not saying anything bad about the current GM trans it's just a bit deceiving.
Let's make this perfectly CLEAR. That's exactly the point you were trying to make. Why beat around the bush and not just throw it out there?
I am however seeing your logic. Since from 1930 or something up until the mid 00's Allison was GM, I then assume that since RAM is/was a Chrysler/Dodge and the Ram logo was associated with same since about forever, and now it's a Chrysler/Dodge/Peugeot/Fiat branded as a RAM, it's all equal in the deception department huh? ROFLMAO.
Based on what I have seen so far, they must be buying some cheaper less potent drugs where the 2024 is concerned. They scaled the ugliness back a little and it almost looks like a Chevy again, well almost. - Grit_dogNavigator III:(
larry barnhart wrote:
and the present 2005 :(duramax dually. chevman
So Larry did you buy a park model in AZ or have you hung up your snowbird hat?
Like you my wife is failing. NO more rving. Not sad but happy to have less stress and being home is good. chevman
I’m sorry to hear that sir. My best to your wife and you. I too understand what you’re going through. :( - larry_barnhartExplorer
and the present 2005 duramax dually. chevman
Like you my wife is failing. NO more rving. Not sad but happy to have less stress and being home is good. chevman - Me_AgainExplorer III
So Larry did you buy a park model in AZ or have you hung up your snowbird hat? - larry_barnhartExplorer
Cummins12V98 wrote:
yes 2001 8.1 3500 dually and the present 2005 duramax dually. Had two turbo 400's one for the 454 and the surprise was the 1986 light 1/2 ton with the V-6 and 2.53 rear gear. Kinda forgot if the 2.53 is correct but something like that and not a 3.73 for sure. Always seemed to be odd but it worked ok. chevmanlarry barnhart wrote:
Cummins12V98 wrote:
I have owned many GM trannies. Never had any issues with any of them. 2 allisons and still have one with no issues. Just my experience for many years.
chevman
To be clear I am not saying anything bad about the current GM trans it's just a bit deceiving. - Cummins12V98Explorer III
The reason they have improved sales is because they changed engine and trans components to keep up with RAM and Ford on SAE towing numbers. - Cummins12V98Explorer III
I'm not going to accuse Ram of using smoke and mirrors but I'm pretty sure if Ram came out with an eight speed tranny to stick behind the HO Cummins they wouldn't need the Aisin name to sell it.
I agree. But reality is the Cummins does not need more gears. - Cummins12V98Explorer III
chevman
To be clear I am not saying anything bad about the current GM trans it's just a bit deceiving. - ksssExplorer
44,056 PostsLatest Activity: Jun 25, 2013
