JimVan
May 28, 2015Explorer
All terrain tires
I will be buying a new set of tires for my van, Costco has a good deal on a set of all terrain tires. My question is do they run any louder or rougher than normal LT tires ?
IdaD wrote:
I think an AT is an ideal compromise tire for a 4wd vehicle that spends time both on and off road. If your tow vehicle never leaves the pavement or only just occassionally sees a gravel road, a more highway oriented tire will probably suit you a little better in terms of ride/handling and traction on-road. But for me, AT tires are the sweet spot.
byrdr1 wrote:I use the Yokohama's AT on both my 3/4 ton Ford and my Excursion and have not had problems with them. I have found most tires a little squirmy the first 500 to 600 miles. I do think a highway tire has more pavement contact and better stability because of it.Hank85713 wrote:
I have BFG which came with the truck and then replaced with the newer ones that came out. 1st 600 miles they were a little squirmy but are fine after that.
been there done that with a nice set of Yokohama's AT design. It was too much with the 5er attached i had to get rid of them and got Micheans. BUT i wish I still had them got rid of them with around 600 miles on them.. NOW you tell me and I took a beating selling them.
randy
oakbowery wrote:
I personally wouldn't put anything but BFG all terrains on anything I own. I've run several sets to 70k miles and could have run them even further. I just put a set of the new tk02's on my daily driver. They grip extremely well in all conditions, no road noise, and as stated....last 70k plus miles. There's not a better all terrain on the market in my opinion.
