Turtle_n_Peeps
Jun 24, 2015Explorer
Paul Clancy wrote:
175-198 pulling hard 10k up big grades. lmm 2009 running transynd Allison synthetic. The only time I've seen higher was when running dex6 and overfilled. I'd suspect if your over 210+ it is overfilled. Proper level is middle of hot level hatch marks at 172 deg at idle in park. Do a visual on the cooler inside the bumper hole as well.
That's what I see.
OP you're waaaaaaaaay over spec at that temp.
44,071 PostsLatest Activity: Aug 16, 2026
