Jetstreamer
Jun 25, 2015Explorer
christopherglenn wrote:
If you hit 260, dump the fluid and replace. Allison spec is 2 dump and fills a few hundred miles apart. would be a good time to pull the two hoses from the side of the tranny and blow out with compressed air (backwards). You may have friction material clogging the coolers. There are two, the primary is a oil to water in the radiator, the secondary is the oil to air in front of the AC condenser. Both need to be clear or you will cook the tranny pretty fast. There are aftermarket oil to air coolers, but at 260 you have far bigger issues - unless the existing cooler is bad.
Great advice thanks... I did get home today and cleaned out quite a few bugs out of the radiator stack and it's going in to a specialty tranny shop Monday. I'll be sure to mention the flush...
44,071 PostsLatest Activity: Aug 16, 2026
