Bedlam
Mar 02, 2018Moderator
Like any specialty tire or wheel you may be using, you should carry a spare if you need redundancy/backup. When I shop tires, I make sure it is a common size that is readily available from multiple sources so I can avoid something like this. If I had chosen to use a 445/65R19.5 tire and matching rim, I would have just as much trouble getting a field replacement as one of those tracks.
44,070 PostsLatest Activity: Sep 18, 2026
