Bedlam
Sep 13, 2019Moderator
If you get any truck frame flex, that will be transfer into forces on your camper frame if directly bolted together. Although it is done, I would rather see a spring load device between the camper and truck for that reason.
If you could slide the camper farther forward so you have minimal overhang, then you would not need a hitch extension. This would allow you to use the existing receiver but you will need to find an alternate location for your auxiliary fuel tank.
