sasq40
Sep 14, 2019Explorer
ticki2 wrote:
If you could make an attaching point to the front jack mount the tiedown would clear the boxes . In the rear add a new mount behind the skirt . Folks are always talking about the camper COG and it's relation the the rear axle , which is important but not the full story . Especially on a flatbed , where there is a lot of storage , where you load the heavy items can change everything . The overall COG of the truck and camper combo is the most important . Generally , if you a r e adding weight to the front axle when fully loaded you are OK . The wild cards are the holding tanks and in your case the aux gas tank which will not remain constant .
Hmm that is another option for sure. I may do a combination of moving the front mount forward and removing the bumper to move the camper forward. I have the equivalent to the torklift anchor relocate kit that I could use to extend the mounts. It may leave the tie downs going straight up and down which isn't ideal.
