Bobbo
Aug 25, 2021Explorer III
Z-Peller wrote:
Easy fix I have done to 3 different rigs over the years that should have been done on installation. I screwed a 1/4” thick board on top of support boards with holes drilled thru in appropriate position and size for rubber feet on bottom of m/w to fit into. Then screw down a front to back board at each end of support boards and attach a poly strap side to side overtop the m/w and screw down to these boards.
Nice. But first, you need to get the support boards UNDER the MW feet. That was my problem.
