goducks10
Aug 06, 2015Explorer
westend wrote:themoreweexplore wrote:An alternative to adding a battery box on the exterior is to install one inside. The box needs to be sealed and vented to the exterior. I have one inside, just forward of the axles. I use two 6V-GC2's in that bank but folks with more money could use AGM batteries in that situation.69 Avion wrote:
Now, as far as trailers go, if I needed a travel trailer, I would really like to find a fairly new Airstream with a cracked or damaged frame. I would remove the shell, make a new frame and have a great trailer. The frame would take me about a week to make, but I wouldn't call it a semi-monocoque system. I would guarantee that it would last the life of the trailer and beyond. It would weigh about 300# more than the factory trailer and have a higher GVW. The hardest part is removing the shell, and reinstalling it.
I've thought of this myself. While the canopy was off, I'd raise it off the ground a bit, add a battery bay near the axle, and then put it back on. Lots and lots of work though.
Not to veer to much off topic, but am I correct in that AGM's don't need venting?
