John___Angela
Jan 07, 2014Explorer
Your dry weight of the trailer is around 5500 pounds. I suspect if you are loaded up with junk and water you will be around 6800 pounds max if you load like most of us. Your tounge weight might top out at 1050 pounds including the EQ and one battery. Don't pack all the heavy stuff in the front storage area. Pack with thought and planning. You will have NO problem with that trailer and the truck is more than suited to pulling it with lots of reserve. GVWR of the trailer is irrelevant. It is a rating not a weight. The bigger the rating the better. Has nothing to do with the weight of the trailer.
Happy trails.
Happy trails.
