pianotuna
May 09, 2017Nomad III
Hi,
Your numbers make little sense.
Almost everyone has or wants an inverter if they camp off the grid, so that is an unfair cost.
If you camp off the grid--you need quality batteries, so that is an unfair cost.
Since 2005 I've had one generator die $1200, one walk away $3000, and the replacement is about $3400. That does not include the cost of fuel, oil changes, and having the generators tuned up.
My solar system has not cost a dime since 2005 and was 1700.
Today, for that same 1700 bucks I can get the parts for a 1000 watt solar system. Installation will be taking old panels off. The wire is already run from the roof so that's a zero cost. I have to add a DC breaker, and a new charge controller (included in the 1700 for parts). I'll be generous and say 5 hours work, most of which I could do myself but I will use my "go to" person. Let's say 2500 or $2.50 per watt installed.
jmtandem wrote:
I wonder where you received the $3,000 approximately cost to go solar. It seems a little low to me for permanent panels, quality batteries, all the hardware and chargers, plus labor if somebody else does the work. None of my comments reflected anything about setting up a new solar system being less expensive than filling a propane bottle. I think solar installation labor costs could easily be $1,000, panels (enough to run the refer and some other stuff) another $1200, charger probably $350 or so, inverter $1200, batteries another $1000, plus a few hundred more in misc parts. Total cost more like $4500-5000. Anyway thanks for the post and thread. It is interesting. I have not read on any RV website that those that went solar regretted it.
44,071 PostsLatest Activity: Aug 30, 2026
