TwistedlarchExplorerApr 12, 2020Amp hoursI'm trying to determine whether my current solar system is adequate or if I need to add more panels/batteries. Currently I have 2 6 volt lead acid batteries. I have 300 watts of panels 40 amp con...Show More
time2rollNomadApr 12, 2020If the idle voltage is 12.2+ when you get up in the morning you are good to go.
Related ContentHow many amp-hours?200 amp-hour Li $799Battery Amp HourAmp Hour questionSolar Charging and Amp Hours
