TwistedlarchExplorerApr 12, 2020Amp hoursI'm trying to determine whether my current solar system is adequate or if I need to add more panels/batteries. Currently I have 2 6 volt lead acid batteries. I have 300 watts of panels 40 amp con...Show More
CavemanCharlieExplorer IIIApr 12, 2020As other people have said the fan in the furnace is the big draw. Try to avoid running that. If you convert your camper lights to LED bulbs they will use very little electricity and you can get by without using the flashlights so much. Sorry I can not answer your question. I'm just trying to give suggestions that will help.
Related ContentHow many amp-hours?200 amp-hour Li $799Battery Amp HourAmp Hour questionSolar Charging and Amp Hours
