TwistedlarchExplorerApr 12, 2020Amp hoursI'm trying to determine whether my current solar system is adequate or if I need to add more panels/batteries. Currently I have 2 6 volt lead acid batteries. I have 300 watts of panels 40 amp con...Show More
opnspacesNavigator IIIApr 14, 2020While nobody can adequately answer your question with the information provided, you should be able to.When the sun goes down are your batteries at 12.7 volts or higher? If yes then you have enough solar. In the morning are your batteries at or above 12.1 volts? If yes then you have enough batteries.
Related ContentHow many amp-hours?200 amp-hour Li $799Battery Amp HourAmp Hour questionSolar Charging and Amp Hours
