Twistedlarch
Apr 12, 2020Explorer
Amp hours
I'm trying to determine whether my current solar system is adequate or if I need to add more panels/batteries. Currently I have 2 6 volt lead acid batteries. I have 300 watts of panels 40 amp con...
Twistedlarch wrote:That suggests 80% SOC, 44Ah draw or 3.7A/hour. An ammeter could confirm in addition to a battery load check for weak batteries.
Hey all, last night I disconnected the shore power from the trailer and let it sit idle for 12 hrs. My voltage started at 13.7 and ended at 12.4. The only things running were the Carbon monoxide detector, stereo (off position), and the fridge which was running on LP.
The batteries I'm running are the 6 volt Interstate GC2 Deep Cycle Extreme (GC2-ECL-UTL) 225 Amp hours 115 min @ 75 Amps.
Brian
