Twistedlarch
Apr 12, 2020Explorer
Amp hours
I'm trying to determine whether my current solar system is adequate or if I need to add more panels/batteries. Currently I have 2 6 volt lead acid batteries. I have 300 watts of panels 40 amp con...
40 amp controller
I'm curious as to how many Amp hours my trailer uses.
Small 3 way fridge running on LP
CM detector
Stereo on standby mode
Water pump
I usually try to use battery powered lights at night.
The kids also watch a movie to unwind at night, the TV and DVD player run on a separate small battery hooked to an inverter. Small battery will be charged during the day from the panels.
We keep water use at a minimum.
I also have two dual USB charging ports.
Heat is set at 60. Night time outside temps can dip down into the high 30's in Spring and late Summer where we usually camp
Our usual camping area is at 4,500-5,000+ altitude with pretty intense sun in the afternoon.
Thanks
Brian
