MM49 wrote:
FishOnOne wrote:
MM49 wrote:
Your Pentastar V6 has an electronic proportioning oil pump in it. You should use only the oil specified for your engine. The engine wasn't tested with a 100% PAO oil.
MM49
Wow... This is a load of BS!
Did you not read the OP stated the Amsoil OE has the correct Chrysler specification. And based on the price for this oil it's most likely a group III base oil.
As usual every thing that you said is wrong.
1 Amsoil is a 100% PAO oil
2 Lubrizol is the oil that the engines are designed to.
3 The Pentastar does have a electronic bypass oil pump. It is controlled by the PCM. The wiring goes through the side of the block to the oil pump manifold.
You are a load of BS....
MM49
1. Amsoil OE at $7.05/quart is not 100% PAO. It's not designed for the extended oil change market. Look up their newsletter on this product.
2. Lubrizol is a oil additive manufacturer. They don't produce engine oil.
3. I seriously doubt the Pentastar oil pump is critical of what type of base oil it's pumping.
What a DB full of BS :W
