GrandpaKip wrote:
.... the Andersen is an excellent choice.
If I had a large trailer, that would change things. Just because the Andersen has its limits doesn’t mean it should be discounted out of hand. As with most things, when used correctly, it works properly.
The problem is those "limits" as you call them are a HUGE NEGATIVE IMO when no one can put firm numbers on them and like you only say "If I had a large trailer, that would change things". AFAIK none of the other have limits, either stated or preceived/noted except weight limits for both the basic hitch and WD bars.
Again, don't shoot the messenger, I'm just passing on what I have read and understand from other owners and their posts/opinions like have been expressed in this thread.
Larry
