wowens79 wrote:
goducks10 wrote:
GDS-3950BH wrote:
I don't get the 10 speed OCD discussions. I drive a different truck every day at work, all 3 US flavors and probably almost every combination at one time or another. Unless your always in Flatlands running empty/not towing and going for squeezing every last drop for fuel mileage, all those extra gears are wasted fluff. In hill country loaded or towing you'll never be up in them much if at all and it does not matter what is in front of the tranny. More gears = more heat and more parts to wear.
Mostly agree. Regardless of gears you still need the same HP/TQ to climb a mtn or cruise the interstate.
However an 8sp or 10 speed will have better spacing between gears and allow the vehicle to maintain speeds easier without lugging or over revving.
Exactly, with my 4 speed GM 6.0 when it down shifts its a 1000 rpm jump. I have so many times that it would be great to have a gear in the middle.
When I'm running on flattish interstate I've have to choose between struggling at 2000 rpm, and reving at 3000rpms, but it be great to have a gear at 2500rpm. I've pulled from ATL to the FL Keys turning 3000rpms and it did fine, but 2500rpms would be perfect.
Considering gas engines have such a wide range of RPM between working with loads and cruising for mileage when empty, the more gears the better. When the 6-speeds came out, they mostly improved the empty cruising with 2 overdrives instead of 1. The grade pulling gears aren't really that different.
When comparing the 6L80E to a 4L80E for example, the 6-speed adds a lower 1st gear but 2-3 are similar to what 1-2 were on the 4 speed. 4th is 15% lower than 3rd was. So practically speaking you didn't gain much in terms of useable hill climbing gears. More would definitely be nice.
