You haven't filled out your profile so we don't know what year Duramax you're dealing with. I just finished installing a BlueSeas ACR and 50 amp breaker to keep the house and truck batteries tied together while the engine is running and separated when not. During that research I found my truck (signature) requires a 40 amp fuse in the aux 12v slot to charge your house batteries. You'll need to refer to your fuse schematic for the location of that fuse. If it was charging and now it isn't, that fuse would be the first thing I'd check.
