Bears_Den
May 09, 2016Explorer
Between the battery and the slide, usually mounted on the A frame is a selonoid or a fuse. Mine has the selonoid and my slideout did the same thing it went in and 5 minutes later it only went partially out. I had a loose wire at the selonoid and contact was not being made. Once that connection was tightened up the slide worked fine. Check that before you spend money on a repair that is very simple. Good luck.
44,025 PostsLatest Activity: Feb 18, 2025
