joem789 wrote:
I understand how the inverter hooks to the batteries. Let me rephrase things a little. Can I build a 200 watt solar system and plug it directly into the camper outlet and run it like usual. I realize that many things will have to be shut off inside the camper to avoid draining the batteries. I just want to know if it will technically WORK and if so, how is the efficiency of the solar system affected by running into the camper electrical system. Thanks.
As I understand your proposal, the simple answer to the above is NO, you cannot do as you suggest. A stand-alone 200W solar system, complete with its own inverter so you can plug it into your TT shore power AC input will only provide you about 20W of 120VAC power at very best ... far too little to be of any use to you.
