shakyjay's avatar
shakyjay
Explorer II
May 11, 2013
Another Tire Question
Time for new tires. Currently have ST205/75/15C's. They are the originals and up til now have been fine however age is taking it's toll and sidewalls are cracking. Stopped at America's Tire. Seems they now are not stocking the Towmasters which was one of the tires I was considering. Instead they have gone back to stocking the Carlisles that supposedly have been redesigned. I have done some research and it appears the new RH does have some improvements. After much discussion with the salesman who actually said he is running the Carlisles on his 13,500 lb. fifth wheel. He recommended that if I have the clearance to go with a Carlisle ST225/75/15 E rated tire. Supposedly it should only require about an 1.25 inches more of clearance. So my options are just replace with original size and range in a ST205 or what my original intent was to go ST205 in a D range or go up to the ST225 in load range E. Price between the three is really not that much difference D range $50 more than C and ST225 $80 more than C. The other option I am considering is to have him order the Maxxis. Price for them in ST250/75/15C is about $100 more than the same Carlisle. He absolutely did not recommend Marathons and said he could order the Towmasters but really did not recommend them either.
So after all that I am simply looking for some input to help me decide which option would be the best. I do not tow full time. Actually now days the trailer sits more than it moves. What travels we do use it for are generally no more than a couple of hundred miles one way. Occasionally we may go a little further. I do not run heavy but would like a little cushion.
